exhaust leak???
Old Nov 8, 2008 | 01:01 PM
jman_08's Avatar
jman_08 is an unknown quantity at this point
Default exhaust leak???
Im not very experianced with the name of exhaust pieces but before the rest of the pipe comes out the back of the truck the big muffler or square piece is leaking water/Condensation out of the rear. of this catalytic converter or muffler does this mean there is an exhaust leak????
Old Nov 8, 2008 | 05:09 PM
abadinalbany's Avatar
abadinalbany is an unknown quantity at this point
Default RE: exhaust leak???
you get water out of the exhaust when you have moisture in the fuel system. try any of the $3-$8 moisture removal fuel additives available at your local auto parts store.
it could also mean you have coolant leaking into the combustion/exhaust aspect of things ...
Old Nov 8, 2008 | 05:18 PM
mysons95's Avatar
mysons95 is an unknown quantity at this point
All exhaust sytems "leak" water. It is condesation that builds up as the exhaust sytem warms up, especially if the air temp is low. ie winter
This does NOT mean you have water in your gas.
If the water is coming out of the very end pipe (the tail pipe), that is OK. But if it is coming out of areas before the tail pipe, then you have a leak.
phatso_99blaz
Headers, Intake, & Exhaust
Apr 8, 2013 03:16 PM
Blessed23
Feb 13, 2013 05:10 PM
CodyT
Mar 20, 2008 03:31 PM
jcoop711
Aug 27, 2007 12:42 PM
HCCAFan
Feb 5, 2007 10:35 PM
