Front driveshaft hitting motor!!!
I'm thinking it has to be something amiss with the motor mounts. I'm not exactly sure on the s-series trucks, but I know quite a few older vehicles have the motor offset to one side.
How does the fan shroud to fan fit look? (2nd time)
OK, more info:
The fan is perfectly centered in the fan shroud. Advance Auto originally provided me with the wrong part, I exchanged for the correct mount (same part #, different box) that is supposed to go in there and it is the same height as my original mount.
Is the 'knuckle' of the u-joint supposed to be in front of the bellhousing? I might be able to move the motor back about 1/4". The mounts on the motor are adjustable front to back- I have to check the holes on the crossmember for room tho.
I installed a new trans mount, and there is about 3/8" between the front driveshaft and the motor. This still seems awful close. How much clearance should there be? Could someone snap a pic?
gitch93
Jan 23, 2013 04:51 PM
Blasir
Feb 7, 2007 09:07 PM
trudynosports
Dec 13, 2005 09:40 PM
