Fuel gauge non-functional
Old 12-05-2017, 07:29 AM
Mike.308's Avatar
Originally Posted by oldeerslayer
If your gauge reads full all the time you have a break (open) in either the black sensor ground wire or the purple signal wire. If it reads empty you have a short to ground.
You need to follow the wires from the sender to the PCM looking for damage, particularly around connectors. Quite often when engine or transmission repairs are done those wires get pulled out of their connectors along the way.
I guess he wouldn't have 80 Ohms reading then.
In regards to the GeorgeLG questions I'd rather assume there could be something wrong with a VCM settings or a damaged input. But the damaged input check is as easy as finding if the "low fuel" indicator gets triggered. If it does, the input is ok.
Old 12-05-2017, 07:33 AM
oldeerslayer's Avatar
oldeerslayer is an unknown quantity at this point
He said he had 80 ohms
between the wires coming out at the pump.
If he has an open or shorted wire past that point that signal won't be what the PCM is seeing.
It would see 0 or infinity.
Old 12-05-2017, 07:57 AM
Mike.308's Avatar
If the feedback line is shorted - it is shorted on both ends.
Old 12-05-2017, 10:36 AM
Whatever.
Not going to argue schematics. Point is if the sender is operating correctly, which it seems to be since 80 ohms is around 1/4 tank, then he needs to follow the purple and black (possibly with a white stripe) back to their sources and find what is damaged.
I'd start by re-connecting the sender and see if he gets 80 ohms across c3 13 and c3 19 at the PCM. C3 is the clear plug.
Splice pack 422 on the LH frame rail, right by the transmission crossmember is a common place for damage and corrosion.
Old 12-05-2017, 01:14 PM
Mike.308's Avatar
Whatever.
Neither do I. I didn't mean to be rude, just give a pure engineering advice (short circuit are excluded). Btw. we did not mention grounded wire...
pinstriped blazer
07-13-2010 12:33 AM
mjcobe89
09-10-2009 09:02 PM
illinois99blazer
13
12-02-2008 07:20 AM
Mulisha
03-24-2008 09:14 PM
Marzocchi65
11-24-2006 04:26 PM
Quick Reply: Fuel gauge non-functional
