Fuel gauge points down after LIM gasket replacement
Old Feb 18, 2012 | 07:06 AM
ckirv's Avatar
ckirv is an unknown quantity at this point
Default Fuel gauge points down after LIM gasket replacement
2001 Blazer LT 4.3.
I replaced the Lower intake manifold gasket last weekend and now the fuel gauge points down to 5 oclock. Did I miss something while putting it back together?
Any ideas? Thanks
Old Feb 18, 2012 | 08:21 AM
pettyfog's Avatar
1. always
2. just when key on
3. where is it key-off?
photos would help
What NON-SOCKET connections did you change? Did you remove grounds on back of engine?
What else doesnt work right?
Old Feb 18, 2012 | 10:36 AM
wyzardd's Avatar
wyzardd is on a distinguished road
Mine does that occasionally if the battery has been disconnected for more than a few seconds. Nearly tore the dash apart trying to fix it the first time. Disconnecting the battery again, then letting it run for a bit (ignition on might be enough) took care of it.
I never did catch it in the act of getting better. I looked at it gleefully pointing down, muttered a few curses, then look back a while later and it's sitting there all casual like nothing was ever wrong.
Old Feb 18, 2012 | 12:11 PM
ckirv's Avatar
It is like that when the key is off or when running. The needle in the dash points to about 5 oclock.
I've only had it running a few minutes so far. Started it up and let it run a few minutes then shut it down to change the oil (then stripped the drain plug). So now I just have to refill it with oil and drive it.
I changed the LIM gasket, valve cover gaskets, plug wires and distributor cap. No plug/electrical connections.
Old Feb 18, 2012 | 12:43 PM
pettyfog's Avatar
Then I suggest it was 'shocked' around into that position. And this may be the answer.. that or a good rap on its face.
Old Feb 19, 2012 | 12:07 PM
walleye seeker's Avatar
walleye seeker is on a distinguished road
i just did the same project mine did the same thing a good couple raps on the cluster face and it popped right around and is working fine
chcknugget
14
Sep 28, 2020 09:25 AM
Joey1986Z
Jun 23, 2014 11:09 AM
kevinph
Feb 26, 2012 09:38 PM
Charder
26
Aug 12, 2011 04:33 PM
stlwaco
Nov 22, 2010 06:05 AM
