Fuel Gauge Problem.
Old Jun 10, 2011 | 12:00 PM
favilac's Avatar
favilac is on a distinguished road
Default Fuel Gauge Problem.
I had problems starting my car cold. Once started I had no issues the rest of the day, and I suspected of a faulty fuel pump. At this point the fuel gauge worked fine.
Last weekend I took a trip and the fuel pump failed at last. I barely got to a small town where a local mechanic confirmed the problem. We were able to get an AC/Delco fuel pump and the problem was solved. I have no more starting issues and completed the trip with no problems at all.
Here's the catch: the fuel gauge is not calibrated. When the mechanic delivered me the truck he told me that the fuel gauge was marking half a tank, but it really only had less than a quarter and that after a filling the tank fuel it would mark correctly. So I filled the tank and the needle went to the "FUEL" letters. I had to take the road again because I was already late. Got to the next town (about 130 miles) and the needle didn't move. Next day I went home (200 more miles) and filled the tank before leaving because I was nervous about much fuel I really had in the tank.
Got home with no issues and this morning going to work I see that needle is indeed moving and now is just a tad right of the Full mark. I'm guessing that I have at least half a tank of gas, and it's marking little more than full.
What can the problem be? The fuel gauge seems to be "working", but is marking wrong. I am 3 hours away from the place where I had the fuel pump replaced so it's almost impossible to get there and get the car checked by this mechanic again.
I'm thinking in disconnecting the battery for a couple of minutes and see if the computer/sensor/whatever resets itself. Will it work?
Thanks in advance!
Old Jun 10, 2011 | 02:45 PM
Sounds like the mechanic bent the float arm on the fuel level sending unit when he installed the pump resulting in the inaccurate level reading.
Old Jun 10, 2011 | 04:40 PM
favilac's Avatar
Anything I could check, before having to drop the fuel tank?
Old Jun 10, 2011 | 04:46 PM
Another thing just occurred to me... If there were something causing a higher than normal resistance in the fuel level sending unit circuit, it could cause the conditions you are experiencing.
This thread is specific to the 98+, but might provide some help to you:
98+ Fuel Gauge Diagnosis
Old Jun 11, 2011 | 01:14 PM
terbates's Avatar
terbates is on a distinguished road
I could see someone "bending" the arm of the sending unit if they weren't careful, and would be surprised if its not that other than electrical
grayman63
Jul 17, 2013 01:56 PM
JonZRDeuce
Feb 5, 2012 06:38 PM
hoppy26
Jan 26, 2012 02:08 PM
Mulisha
Mar 24, 2008 09:14 PM
