More a/c help please
Old Jun 11, 2011 | 05:05 PM
colesdaddy02's Avatar
colesdaddy02 is on a distinguished road
Default More a/c help please
I had to replace the high pressure port valve as it was leaking, my question is how do i tell if i have any more leaks before i go get it vacummed and charged.I thought about putting the dye in it but the guy at the auto parts told me not to run it until I get it evacuated. Any help would be appreciated so I can get my truck back from my wife.
Old Jun 11, 2011 | 05:18 PM
trucktom's Avatar
trucktom is on a distinguished road
that depends what and how you install the dye... now is the time in my opinion, while system is empty, pick an easy access point a good one is the accumulator. pour die in the line or any other connector that is easy to access. then have vac and charged. if you go to a shop they can put die in 4 you while they charge it. dye is a solvent so never use more than a 1/4oz per system or it will cut the oil. make sure caps go back on and rubber seals are in them, they are considered a secondary seal, nut just a dust cap. thats it, the gas will distribute it evenly when system in ran.
Old Jun 11, 2011 | 05:39 PM
Yeah, that makes sense. I was hoping I could check for leaks before I had it charged just in case it has another leak then all the new refrigarant would leak out.
Old Jun 11, 2011 | 05:49 PM
trucktom's Avatar
well u can, kinda lol. u can put a little gas in and listen, charge w nitrogen and use a gas sniffer, or have vacumed and wait a few days and make sure it holds. when i do a/c repair, i vac and moniter gauges for 30 minutes. if drops a little and then holds, i know i have moisture in the system, if it drops right off u have a gaping leak. if not believed to have a gaping leak and doesnt show immediatly then dye and charge is fool proof. if is a better shop, they may have a gas sniffer and can check while they charge for a moderate leak.
johnjfeher
May 20, 2013 04:21 PM
Chenzo
Engine & Internal
Mar 29, 2011 01:56 AM
dwhittaker
Mar 14, 2011 02:18 PM
dougs10
Dec 14, 2010 03:24 PM
rogggg1020
Nov 11, 2008 08:05 AM
