Gots no heat (cant get the hose off)
Old Oct 2, 2007 | 04:22 PM
getonerd's Avatar
getonerd is an unknown quantity at this point
Default Gots no heat (cant get the hose off)
I need help with my heat i thinks it my heater core i change the thermostat but no heat i was going to flush out the core but i cant get the heater hose off i was just cut the hose and get new ones but if i can save them they are in good shape
any sug[/align]
Old Oct 2, 2007 | 05:31 PM
Default RE: Gots no heat (cant get the hose off)
For stubborn radiator/heater hoses, I typically use a flat blade screwdriver between the hose and the fitting it attaches to. For hard to reach areas, I made up a 'J' shaped tool for this purpose. All that is really necessary is to break the bond between the hose and the fitting in one area, then work it the rest of the way off.
Old Oct 2, 2007 | 05:44 PM
woodsballr's Avatar
woodsballr is an unknown quantity at this point
yea i had that problem when i changed mine. just twist it and pull and itll come off. just dont get your face too close or youll wind up with a bloody or busted nose lol. yes ive been there and done that.
Old Oct 9, 2007 | 02:54 PM
blzR's Avatar
blzR is an unknown quantity at this point
'J-shape' pic request Swartlkk?
Old Oct 9, 2007 | 05:05 PM
Just heat up and bend an old screw driver. I can't seem to find mine now... I used a longer than normal flat blade screw driver. I think my dad may have it now and if that is indeed the case, I'll probably never see it again.
Old Oct 10, 2007 | 01:30 PM
user 1016's Avatar
user 1016 has a spectacular aura aboutuser 1016 has a spectacular aura about
just don't yank on it (or any other forms of forcefully removing it) it could crack the core...
Old Oct 12, 2007 | 05:31 AM
richblaz99's Avatar
richblaz99 is an unknown quantity at this point
You could try to have a power flush in aradiator shop to get rid of the dexcool ,and chek if there's some kind of muddy stuff coming out. If so , change for regular green coolant,50/50 mix with water.
Old Oct 12, 2007 | 07:49 AM
getonerd's Avatar
im going to try that it 35.00 at my local shop
koreiryuu
Dec 22, 2014 11:28 PM
moon
Nov 28, 2011 07:53 AM
wlorton
Jun 23, 2010 11:12 PM
dirtydave
Lifting Tech
Nov 27, 2009 01:47 PM
fortmyerspolice
Feb 19, 2006 10:56 AM
