Hard Starts
Old Feb 4, 2013 | 07:30 PM
Awesome's Avatar
Awesome is on a distinguished road
Default Hard Starts
My Blazer has a new (40k miles) engine, and it's always started right up on the first try, catching before it makes a full revolution.
Recently, when it is cold, it has had to crank for a few seconds before it catches, and occasionally it runs really rough for a few seconds upon catching.
This only happens when the engine is cold, and it doesn't matter how long it's been sitting. Fuel type is not the issue, and the pump is working.
Any ideas?
Also, I think it's pretty funny that Ford advertizes on a Chevy forum.
Old Feb 4, 2013 | 08:48 PM
Check fuel pressure and leakdown first, classic symptoms of a failing pump.
1997 ignition switch is unique to 97 and is known to have "issues" that can cause several different, (seemingly unrelated) problems with engine performance & transmission shifting.
Old Feb 4, 2013 | 08:56 PM
4x4blazerguy's Avatar
Cool
Any ideas?
When you build JUNK you need to try & catch a sucker anywhere you can.
Old Feb 4, 2013 | 08:57 PM
Awesome's Avatar
Ignition switch as in the thing I stick the key in?
I'll get a fuel pressure gauge and check that, thanks.
Old Feb 4, 2013 | 09:05 PM
Not where the key goes in, that's the lock cylinder. The ignition switch is inside the column cover, near the lock cylinder, and looks like this:
Old Feb 4, 2013 | 09:08 PM
Awesome's Avatar
That looks expensive and hard to get to.
Old Feb 4, 2013 | 09:24 PM
Labor time is 1.5 hours, longer if you've never done one
Buy ACDelco Ignition and Start Switch D1498C at Advance Auto Parts
Test fuel pressure and leakdown first. Key ON, engine OFF, fuel pump running: pressure must be 60psi to 66psi and must remain above 55psi for at least 10 minutes after the pump shuts off.
Old Feb 4, 2013 | 09:57 PM
Awesome's Avatar
Ouch. I'm already spending a bunch of money fixing up the Jeep. Haha.
I'll check the fuel pressure. The neighbor has a tester.
CountryRed
Jul 22, 2011 05:47 PM
KKZWasson
Aug 17, 2010 07:28 PM
miamiii13
Apr 13, 2009 04:56 PM
dalifts
Jan 25, 2009 07:13 PM
alan98296
May 8, 2007 01:06 PM
