Hard Vibrating at idle
Old Jun 29, 2010 | 05:47 PM
Blazer772's Avatar
Blazer772 is on a distinguished road
Exclamation Hard Vibrating at idle
i have a 2000 chevy blazer its got the 4.6 v6 178xxx mileage,the concern i have is that it idles hard but when your driving its fine . It had bad engine mounts and those were replaced , did a full tune up plugs cables filters,oil change,distibutor cap.Fuel economy is also very bad.It has no cat converter ?could that have something to do with it ? have one i bought new at advance autoparts for $97 just havent gotten around to putting it in.I think it could be a sensor?
Old Jun 29, 2010 | 07:06 PM
Is the check engine light on? What are the codes?
Have you checked over the vacuum lines for leaks? Cleaned the MAF sensor, EGR valve, and/or throttle body (including IAC valve)? <-- much of that is explained in other threads so search up.
Old Jun 29, 2010 | 07:21 PM
Blazer772's Avatar
yes the check engine light is on , i checked it and all i got was "engine misfire" checked spark pluug wiring and its correct.where is the maf sensor located ? what is used to clean it?
BBurton321
May 4, 2011 11:23 PM
troyky29
Feb 8, 2009 03:36 PM
Syres1
Oct 12, 2008 02:13 PM
elementalnature
Jul 9, 2008 06:47 PM
Dturner14
Jun 30, 2007 11:32 PM
