Heater selector vaccum leak?
Old Aug 15, 2015 | 04:06 PM
PhantomZ's Avatar
PhantomZ is on a distinguished road
Default Heater selector vaccum leak?
Hey guys, I'm sure this has probably come up somewhere but couldn't find any info on it. Now my issue in my 95 chevy blazer the heater blower works fine but as you go down the road it changes from vent to say defrost. but only does it under load, do i maybe have a vacuum leak in the dash? just wondering if anybody else has had this problem. I've checked all the lines that i could see and they all look fine. Thanks any help would be great.
Old Aug 17, 2015 | 06:02 PM
94s10blazin's Avatar
94s10blazin is on a distinguished road
same problem 94 thought replaced my check valve at the manifold connectors didnt help . i have 18inHG at idle all systems seem to work fine till i go underload for awhile. lmk
Old Aug 18, 2015 | 11:38 AM
LesMyer's Avatar
Probably unplugged from the vacuum reserve tank inside of the left inner fender close to the firewall. Difficult to see where the line goes so someone may have plugged the line off without the vacuum reserve tank teed in.
<iframe width="640" height="360" src="
" frameborder="0" allowfullscreen></iframe>
Old Aug 18, 2015 | 01:12 PM
PhantomZ's Avatar
thanks for the response guys .. the vacuum is ok at the check valve i replaced that and the reserve tank on mine is a bulb attached to the hood. do those even go bad?. I'm thinking it a line in the dash, does anybody have a vacuum diagram of the vacuum lines in the dash?
Old Aug 19, 2015 | 09:45 AM
LannyL81's Avatar
There is a diagram...but the "short" is that all vacuum lines begin at the HVAC controls and go to each vacuum actuator inside the dash.
And yes the reserve tanks on the hoods do go bad it someone has cracked it. With the engine running for a minute or so, pull the hose off the bulb and listen for the vacuum escaping.
But also check all of the vacuum hoses under the hood. These rot-out and leak. Replacing is easy, cheap and easy to do.
Old Aug 19, 2015 | 12:22 PM
PhantomZ's Avatar
Ok, I'll have to check that out thanks Lanny. so basically each actuator works for each selection like vent, defrost etc?
scotties19681968@hotmail.com
Oct 8, 2013 04:40 AM
yardbird
May 14, 2013 01:21 AM
lac8362
Nov 2, 2011 08:17 AM
warthogdriver
Mar 4, 2010 03:50 PM
SWATPARAMEDIC
Jan 1, 2010 03:12 PM
