Help with 97 light switch and defog switch
Old Sep 6, 2008 | 02:58 PM
JediKnight2's Avatar
JediKnight2 is an unknown quantity at this point
Default Help with 97 light switch and defog switch
Can someone with a truck that has the headlight and defog switches like a 97 Jimmy go out and test something for me this evening....
I need to know if your marker/headlight switch illuminates when your lights are on at night...you know that light green glow like the window switches
I also need to know how your defog switch works...does it click to one side or the other or does it go back to center when you push it to on or off....
THANKS in advance!
Old Sep 7, 2008 | 12:17 AM
danmiranda's Avatar
danmiranda is an unknown quantity at this point
Default RE: Help with 97 light switch and defog switch
I'll check for sure tommorow, but I think the illuminate.
Not sure about the switch, will check tommorow.
Old Sep 7, 2008 | 03:32 PM
Thank You sir....I look forward to hearing what you found.
Old Sep 8, 2008 | 02:06 PM
danmiranda's Avatar
For mine it goes to the left, then back to center.
Old Sep 8, 2008 | 04:06 PM
OK..so it is working...turn off, back to center, turn on back to center...
How about the headlight switch...does it light up at night?
Old Sep 8, 2008 | 08:24 PM
NVANZEE's Avatar
it should light up. mine does but it is a pp and its a blazer. shouldn't be much off a difference though.
Old Sep 9, 2008 | 03:37 PM
danmiranda's Avatar
Yep sounds right.
Also my switch does illuminate.
Old Sep 11, 2008 | 07:58 PM
Well...I took things apart today and I can say that the parking and headlight switch DOES NOT light up. I took the switch out and took it apart and there are no bulbs in there. There isn't a bulb in the dimmer switch either. There ARE bulbs in the hatch switch, defog switch and wiper switch....those can be removed and replaced as well. Same for the driver window controls, they light upalong with the lock switch, lockout switch...I am fairly sure the mirror switch lights up, but I have it disconnected as it almost started a fire in my truck.
Rags58
Jan 19, 2010 06:21 PM
drummerdude
Dec 27, 2009 10:41 PM
fahzie
Sep 19, 2009 03:12 PM
EuroGoldLS
Oct 23, 2007 07:17 PM
stevelknievel
Aug 22, 2007 03:12 PM
