Hesitation!?
Old Jun 17, 2009 | 03:55 PM
SWANNERZ's Avatar
SWANNERZ is on a distinguished road
Originally Posted by mikeinwi
did you read the link swartlkk posted? at the bottom of the post says if it is the balance shaft it can be corrected by installing a timing chain tensioner.
Whoops! K got it, but there isn't any "rattle" going on. Just a quick hesitation/stall like nuisance going on around the higher rpm's listed.
Old Jun 17, 2009 | 06:40 PM
The rattle may not be enough that you can hear it, but enough that it makes the knock sensor think detonation is occurring.
Old Jun 17, 2009 | 09:01 PM
SWANNERZ's Avatar
Unhappy
Originally Posted by swartlkk
If it is always from around 1800-2200RPM consistently, it is possible that this is resulting from torsional vibration in the balance shaft that is triggering the knock sensor, retarding timing and hindering performance.
This is documented in TSB 03-06-01-024.
I'm assuming if you bring your blazer in for this TSB 03-06-01-024, and they find it to be a needed repair, we will be paying for parts & labor right?
swartlkk, thank goodness for you and your plethora of knowledge!
Old Jun 18, 2009 | 11:51 AM
TSB's are released to help technicians diagnose common problems more easily. They are not recalls so any shop rates and materials costs will be applied to the repair.
You can do this repair yourself if you are mechanically inclined. It is not too terribly involved, but removing the timing cover can be a bit of a pain (oil pan needs to be loosened and dropped in the front).
Old Jun 18, 2009 | 03:12 PM
SWANNERZ's Avatar
I was looking at some of the other TSB'S and #02086 looked like it could be the solution as well. Intermittent Neutral at takeoff, or steady speed.
Old Jun 18, 2009 | 06:36 PM
I cannot find the text for that TSB...
Old Jun 18, 2009 | 09:05 PM
SWANNERZ's Avatar
TSB Number:02086 NHTSA Number:10007782 TSB Date:January 1, 2004 Date Added to File:July 12, 2004
Failing Component:
Power Train
Summary:
4l60e, 4l65e intermittent neutral from a stop or steady speed.
This is all I could find without having a Alldata account. It sounds interesting though.
thebaf
Engine & Internal
May 18, 2006 01:08 AM
blazergirl15
May 15, 2006 12:13 AM
black19
Engine & Internal
Feb 22, 2006 12:13 AM
wahhen
Jun 10, 2005 10:56 PM
jp5162
Mar 1, 2005 10:11 PM
