HI guys new to the forum
Old Jul 6, 2012 | 07:23 PM
  #21
Zzzblazer95's Avatar
Zzzblazer95 is on a distinguished road
Alright heres what i came up with i just figured it out right above the plastic box along the gas pedel side theres a vacuum actuator right above with 2 hoses brown going in and the black one connects underneath the canister thingy duh just like the picture shows that i had circled earlier if you look at the pictures i have posted with the schematics you should be able to locate the heat vacuum line colors and trace them for your leak while your dash is apart i tried getting this done before you tore yours apart im so sorry but check out my pictures and you should be able to locate the vacuum color you need to find for your heat are you sure its connected tightly behind you ac/heater control next to your stereo? It looks like yours is the same lines im dinking with to the lower mode actuator the brown and black hoses check those out for your heat for a leak the actuator you cant really see up there you just have to feel for it i removed the plastic piece you see under the dash in front of the console but i think you should beable to feel for it i did notice the black hose didnt take much to slide on the actuator so it could be leaking around that one the brown one has a strap around it so it cant go anywhere try to find that actuator check for leaks if your dash is still apart.
Old Jul 7, 2012 | 04:54 AM
  #22
Thogert's Avatar
Well I think I'm not going to worry about it until fall when I actually start using the heater again.
Old Jul 7, 2012 | 05:02 AM
  #23
Sounds like a plan its always better to work with plastic and vacuum lines in the warmth instead of the cold tho :-) Hey man thanks again for all your help i really appreciate it. It's nice to see someone trys to help me out :-)
Old Jul 7, 2012 | 05:04 AM
  #24
Thogert's Avatar
I don't, but you can try the for sale section here.
  #25
Do you know anyone looking for some GTS clear headlight covers for the 94-97 blazers with only the composite headlights?
Old Jul 7, 2012 | 05:07 AM
  #26
Thogert's Avatar
Well you would start a post saying that you have something to sell. Add pics and a price and then you wait.
Old Jul 7, 2012 | 05:08 AM
  #27
What do i search for?
  #28
Thogert's Avatar
Stupid servers have the wrong times again. (at least that's what I thought that was the problem last time.)
Old Jul 7, 2012 | 05:15 AM
  #29
Oh ok i was just making sure my other forum dont like it when you post in the wrong category for the post i just wanted to make sure. Thanks have a good one.
Old Jul 7, 2012 | 05:22 AM
  #30
Thogert's Avatar
arob5848
Aug 12, 2011 03:54 PM
hdelgad1
Nov 19, 2008 07:00 AM
NickoDaFsh
Oct 3, 2008 03:14 AM
ali1
Mar 15, 2008 09:41 PM
88GTFormula
Sep 23, 2006 09:34 PM
