Hinges
Hinges
My truck's hinges are in pretty bad condition, even after a bushing kit the door still sags by between a quarter and a third of an inch. the passenger door is even worse as its bushings are missing entirely and the hinges are completely toast on both sides
What are my options for repair?
Maybe something like this:
https://www.rockauto.com/en/catalog/...hing+kit,10711
Several vendors offering the replacement hinges including the pins. Needs to remove the doors, drill out the factory welding spots.
Some writeups in the forum as well.
https://blazerforum.com/forum/2nd-ge...r-hinge-95635/
https://blazerforum.com/forum/paint-...-blazer-89222/
Check your A-pillar around the area of the hinges for cracking, bending. If the pillar is junk... no repair before that has been fixed.
Bolt on replacement will probably need fabrication. Only with proper tools and equipment and know-how it will be a lasting repair. The hinges have some incredible loads on them. Door, lever arm, weight. If someone hangs on the door even worse. Several hundred foot pounds of torque. A nice example are the destroyed pins in the first article.
As one of the articles says: It is a precision work! Any little amount off at the hinge and the door is off by an inch where the lock is.
Check the locking side as well. I suspect hinges going bad after the lock has gone bad.
ChevyHead
07-30-2015 09:44 PM
