how to disconect the fuse block?
Old 02-17-2009 | 03:23 PM
justin1795's Avatar
justin1795 is an unknown quantity at this point
Default how to disconect the fuse block?
ive got a 98 blazer and im pulling the motor. i wanted to disconect the main harness over the engine. i puppled the fuse block from the mount. i fliped it over and loosened the bolt and it begain to raise up. but even after the bolt was all the way loose it wont pull out. i tried the other ones and same thing so there must be a trick.
Old 02-17-2009 | 06:00 PM
Default RE: how to disconect the fuse block?
If the bolt is all the way loose, then you just have to pull. That is all there is. I used a small screw driver to help coax the connectors out.
Joann
10-14-2013 11:33 AM
lil_blazin
05-10-2009 06:20 PM
celchlepp
11-18-2008 12:16 PM
rex
04-04-2008 10:26 PM
navysar
12-05-2005 05:20 PM
Quick Reply: how to disconect the fuse block?
