Ignition switch removal 1997~ Help
Old 05-08-2010 | 09:40 PM
austinlee's Avatar
austinlee is on a distinguished road
Default Ignition switch removal 1997~ Help
I need help getting the ignition switch removed. I have the reverse torex bolts loose and the top cover is only being held on by the key switch. I can not get the key switch out?
Old 05-08-2010 | 11:53 PM
R134A's Avatar
R134A is on a distinguished road
I do not know why you are removing your ignition switch but if the key still works you need to put the key in the run position and there should be a pin that you push in and ignition switch should slide out. If it is damaged and key will not work you need to drill out the pin to remove it.
duckland23
08-03-2012 10:36 AM
fireman11368
08-26-2011 12:18 PM
bigcheese
03-21-2011 11:32 PM
Sass_e
11-05-2009 11:12 AM
Sass_e
11-01-2009 04:00 PM
