I'm all out if ideas... 98 blazer 2door 4x4 help
1. Driver selects 4HI on Transfer Case Shift Select buttons (TCSS)
2. The TCSS sends a request to the Transfer Case Control Module (TCCM). The TCCM has input signals from other items like speed sensor, etc. If all the signals are correct:
3. TCCM sends demand to the Encoder Motor.
4. The Encoder Motor shifts the Transfer Case to 4HI.
5. Transfer Case (in 4HI) activates (closes) the Vacuum Switch. When the Vacuum switch is open, it is venting to the atmosphere.
6. Vacuum is sent to the front axle actuator.
7. The actuator pulls the cable which moves the fork to lock in the front axle.
8. When the front axle locks in an electric signal is sent back from the front axle electrical connector to the TCCM which in the end sends signal to light up the 4HI lamp on the TCSS.
Let's back up a little here, what type of transfer case do you have? It's on a metal tag on the transfer case.
If I were in your shoes, I would start with the test for fault codes as listed in the DIY thread https://blazerforum.com/forum/tech-a...ill-help-7180/
TFitzy16
Jun 3, 2015 07:18 PM
melstal
Mar 24, 2014 05:13 PM
turtle21505@verizon
Mar 2, 2009 02:27 PM
