infomation center problem
2000 Blazer LT 4 wheel drive.Has the information center(compass and shows outside temp and fuel economy etc)There seems to be a problem with the temp sensor. Does anyone know where the temp sensor is located and if it is an easy repair? Any advise on this problem please.
Temp sensor is behind the grill on the hood latch support (center of the radiator).
Is it easy to replace?
Yeah. You have to pull off the grill (snaps in - don't forget to unplug your turn signals) and it'll be right in the middle on the hood latch support bracket.
If you unplug it, I believe it should go to something like -20 or something really low. If it doesn't, then you may have a wiring fault.
Here's the location of the two sensors:
![](http://s11.photobucket.com/albums/a187/swartlkk/2000%20Bravada/th_amb_temp_sensors.jpg)
matthewp
04-04-2021 09:16 PM
ibyz
02-12-2010 01:21 PM
