Leaf Springs for Towing
I'm going to be using my blazer for hauling cars on a dual axle trailer. I just was wondering if anyone knew if the leaf springs off a 2500 or 3500 would bolt up without any modifications. My other option was doing an add a leaf kit. I'm just looking for some more support in the rear. I found an add a leaf kit for $45. I think a new leaf set from pull apart would prolly cost the same. Anyone have any tips?
Thanks!!
Thanks!!
The Blazers are not rated for pulling that much weight. I think the max is about 3500 LBS. Once you have your 1000 lb trailer and a 3500-4000 lb car your going to kill the transmission. You would be better off getting a full size 1/2 ton truck. Plus that much weight would push you all over the road. Its not so much a matter of going as it is stopping. These are basically 1/4 ton vehicles.
My 2000 Blazer manual says with a 4x4 auto 3.42 gears, I can tow up to 5600lbs.
Install a trans cooler and go the extra mile and get a trans temp gauge.
Stopping? Get a trailer with electric brakes.
You may not need to add more leaf springs. If your trailer is dual axle, and loaded CORRECTLY, you can keep the tongue weight down.
Thanks for all the replies. Our trailer is a double axle with brakes. Just put a new set of shiny brakes on, and plan on replacing them often. Stock torque converter was going, so when I rebuilt the engine, I put in a beefier one.
