Measuring current draw on battery
I'm trying to chase down a dead battery problem on a 97 Jimmy. I used a multimeter to test the battery draw, and I'mgetting 25ma draw which drops to 5.5ma when the radio fuse is pulled. Is this enough to drain a battery over night? Is this a typical amount of draw for the radio circuit? Its a factory radio BTW.
Also, will opening the door wake the BCM? I had the door open (necessary for fuse access...)with the courtesy lamp fuse pulled. The ignition had been off for more than 20 mins before testing (and I didn't turn it on at all during testing).
I believe that opening the door will wake the BCM. Try removing the door jam switch and then waiting 20 minutes before re-testing.
Rule of thumb for battery parasitic load is ....check the battery reserve capacity and divide by 4. For example if the battery reserve is 90 minutes, then 90/4=22.5 so parasitic load should not exceed 22.5 milli amps.
yarinzim
02-24-2013 12:09 AM
rwrows
36
07-25-2008 12:13 PM
