mystery bracket
Old Sep 19, 2008 | 05:56 PM
frostgrey's Avatar
frostgrey is an unknown quantity at this point
Default mystery bracket
I recently bought a 96 Blazer with the 4.3 motor to fix for my daughter. The engine had been torn down as far as the block and everything thrown in the back. My guess was when they ran into the plasticinjector lines being broken. I have done a valve job replaced the injectors and put it back together, but I have a bracket (stamped steel # 15724378) left over that I can't find a place for. It is kind of a modified "c" shape with a tail where it bolted to something.
I will try to get an image of it. Any ideas where this might go ?
Thanks
Old Sep 19, 2008 | 06:19 PM
Default RE: mystery bracket
A picture would help!
Old Sep 20, 2008 | 11:07 AM
frostgrey's Avatar
Here are some pix I took, hope they come thru, I had a hard time figuring out how to shrink them.
[IMG]local://upfiles/12077/7A469D08CE3B4AC48E6FD68CD9E6517C.jpg[/IMG]
[IMG]local://upfiles/12077/A548487B36B44345B07DC1697B497C65.jpg[/IMG]
[IMG]local://upfiles/12077/6A5829FDA6F642E4B6679794A99181D5.jpg[/IMG]
Old Sep 20, 2008 | 11:17 AM
Bad Ramer Jamer's Avatar
Bad Ramer Jamer is an unknown quantity at this point
This is just a guess from memory. But it looks like it beto what goes on the box that is under the drivers side rear bumper end. I think it might be something to do with emision stuff,,,,but I dont know. Take a look under the fuel door and see if there is a square box. That might be the mounting bracket. Again,,,just a guess.
Old Sep 21, 2008 | 12:47 AM
frostgrey's Avatar
Thanks, It does look like it, but it only has the one hole. It was in a bucket with the pwr. steering pump, air cond. compressor, large cast bracket to hold those and a bag full of nuts and bolts. The guy I got it from said it came off the motor somewhere.
Thanks again for trying though.
Old Sep 21, 2008 | 04:53 PM
josh05's Avatar
josh05 is an unknown quantity at this point
that bracket supports ur upper radiater hose it bolts onto the front exhaust manifold bolt on ur drivers side
Old Sep 22, 2008 | 08:51 AM
frostgrey's Avatar
Thanks, I had noticed one of the exhaust bolts was a stud. I didn't know which hole it was used on, but now that you said this I moved it to the front hole on that side and everything works out. I appreciate it.
Old Sep 22, 2008 | 10:26 PM
josh05's Avatar
ur welcome glad i could help
ZR 2
Jun 5, 2008 11:17 PM
MVPalmer271
Dec 30, 2007 12:41 AM
mojoman13
Nov 15, 2007 07:42 PM
Swain
Aug 27, 2007 05:01 PM
WisdomRacing
Jul 18, 2007 04:18 AM
