in need of timing help plz!!
Old Nov 7, 2012 | 08:18 PM
  #31
Block 180 out??? There is a possiblity the camshaft is not timed with the crankshaft properly. That can happen when the timing chain is replaced, or it jumps on the gears, but timing chain issues are almost unheard of on 4.3's. I thought all you did was cylinder head gaskets & intakes, no need to mess with the timing chain to do that. Did you even have the timing cover off? Did the engine run before you did the head gaskets?
Old Nov 7, 2012 | 11:06 PM
  #32
Black99blazer's Avatar
Black99blazer is on a distinguished road
Correct all I did was head and intake gaskets. And yes it ran before I took it apart just overheated.
Ya the block 180 out didn't really make sense to me either. The only thing that I can find that's right are the exhaust gaskets.
Old Nov 8, 2012 | 11:43 AM
  #33
The only thing I can find that's NOT right are the exhaust gaskets. They all need to be replaced except for the headers to motor.
I have got the rotor pin lined up on the 6 again at tdc and still no start and its starting to rain for a day or 2 so I won't be able to work on it but I left it at tdc and pulled the cap and its still pointed at the 6 so when it's done rainin I will try to pull the dizzy and drop it back in 180 from where the 6 is. I seem to have the best luck with it like that so far. 😡
m3ch
May 20, 2010 07:50 PM
gmc97jimblaze
Feb 7, 2010 12:35 PM
gojo83
Dec 7, 2009 10:32 AM
SexiBlazerGURL
Nov 2, 2009 07:30 PM
familyman
Aug 25, 2007 04:34 PM
