no sparks 96 blazer
no sparks 96 blazer
ok i put on new coil / wires /plugs / cam module/wires had the icm tested its good /cap and rotor button so what else could there be there is no spark from the coil at all
You might check the control module or the hall effects crankshaft sensor in the distributor.
Definitely have a look into the CKP and CMP sensor wiring and output. Connect a multimeter each sensor (one at a time) and read the output as you turn the engine over by hand. If you are not getting any output with the key on, then there is a problem with the circuit.
Try a search for "CKP" and "CMP" for wiring diagrams and pin outs.
