Oil Cooler Lines Repair
Old Mar 26, 2015 | 07:24 PM
Bagherra's Avatar
Bagherra is on a distinguished road
When u lift the engine, does anything need to be unbolted?
Old Mar 26, 2015 | 07:28 PM
The through bolt in the driver side motor mount, that's it. If you try to lift the engine without removing the bolt, the mount will rip apart, and they are NO fun to replace.
Old Sep 16, 2015 | 09:03 AM
TMM217's Avatar
TMM217 is on a distinguished road
What's the need for lifting the engine? I'm in the middle of a front suspension repair with axle out and I don't think I would have to do that with axle out.
Old Sep 17, 2015 | 11:55 AM
Toby Hanson's Avatar
Toby Hanson will become famous soon enough
The reason for lifting the engine is because the end of the oil cooler lines that bolts onto the oil filter adapter on the bottom of the block won't fit between the engine block and the frame. By unbolting the driver's side engine mount and lifting the engine up by a couple inches it creates the clearance needed to get the end of the cooler lines past the block.
Vahomboy
Jan 3, 2015 09:47 AM
fslobodecki@yahoo.com
Apr 15, 2011 03:29 PM
subarugt06
Mar 6, 2011 11:21 AM
Jetfixer
Jul 11, 2006 05:02 AM
zero psi
Oct 28, 2005 04:45 PM
