One HighBeam
Old Nov 19, 2005 | 12:06 AM
timetoblaze's Avatar
timetoblaze is an unknown quantity at this point
Default One HighBeam
i recently noticed i only have one highbeam so i bought a new bulb and that didnt fix it... i have put a couple bulbs in thinking that maybe somehow i ruined the bulb putting it in but nothing..... im not to savy with wireing so does anyone have any suggestions? thanx
Old Nov 19, 2005 | 03:44 PM
Default RE: One HighBeam
Well, I believe that the headlight wiring is routed through one fuse for high and one for low and basically has the same wiring side to side... You'll probably want to start by inspecting the plug. New plugs can be purchased at pretty much any autoparts store. If you find that the plug is bad, you really should have the wires soldered up, but if you don't know how or don't have a soldering iron, butt-connectors and shrink wrap will suffice.
If the plug looks ok, then you have to start looking into the wiring. It is possible that a wire has been cut. You'll just have to follow the wires (which would involve dismantling the wiring harness)...
Good Luck
Old Nov 20, 2005 | 02:36 AM
well lets hope its not the wires lol thanx
Old Nov 20, 2005 | 09:52 AM
Wiring isn't as big of a problem as a LOT of people make it out to be. Now, wiring inside a house... Well, I'm contending with that right now! Much different, although there aren't as many 'different' wires, just a lot higher volts/amps. If nothing has happened (aka a wreck or work done around that area that moved panels), then I'm leaning towards a corroded headlight plug. Wiring is not a mystical area, but soldering is kind of tied into it. If you wanted to learn how to solder, I'd recommend purchasing a soldering pencil, some solder, soldering paste, and some automotive wire. Then use the wires you bought to practice on.
Good Luck
dusktiger
Oct 9, 2014 11:12 PM
j80
Jan 9, 2010 05:01 PM
TheDesertFox
Oct 9, 2006 08:14 PM
BlazerChick
Apr 24, 2005 03:14 AM
timetoblaze
Mar 13, 2005 10:09 PM
