oxygen sensor trouble codes and "fuel trim" code, i just got new o2 sensors....
Old Apr 26, 2010 | 12:47 PM
drin's Avatar
drin is on a distinguished road
Default oxygen sensor trouble codes and "fuel trim" code, i just got new o2 sensors....
i got trouble codes p0151, p0131, p0137 and p0171.....
151,137 and 131 relates to each one of the o2 sensors, 131 says engine running lean. 171 states a fuel trim bank one condition....now i know my o2 sensors aren't faulty, they were replaced about a month ago. and weird thing is i noticed my car getting BETTER gas mileage, and it says its running lean....so i have no clue if all these coming together means something. I was thinkin my maf sensor but the other thing is i haven't noticed any weirdness while driving my car. Is it possible a spark plug could be causing this? Cause i did change them not too long ago except one cuz the steering column is in the way and im just too lazy to take it out to change it. ive had fuel pump problems in past cars, and i dont think its that cuz my engine doesn't try to stall at all. I do need to use fuel injector cleaner cause my oil change is about due but i dont think fuel injector cleaner is going to help this out cause 171 correlates to possible fuel injector problem. So what do you think?
Old Apr 26, 2010 | 12:51 PM
What are you driving?
P0131 - HO2S Circuit Low Voltage Bank 1 Sensor 1
P0137 - HO2S Circuit Low Voltage Bank 1 Sensor 2
P0151 - HO2S Circuit Low Voltage Bank 2 Sensor 1
P0171 - Fuel Trim System Lean Bank 1
Start with the trouble shooting steps in the links above. See where that takes you.
*EDIT* - Here is the description for P0137. I do not have it in my other reference though.
DTC P0137 - HO2S CIRCUIT LOW VOLTAGE BANK 1, SENSOR 2
Circuit Description
VCM provides about 0.45 volt reference to Heated Oxygen Sensor (HO2S). HO2S sensor signal voltage varies from about one volt when exhaust is rich to about 0.1 volt when exhaust is lean. VCM reads and stores sensor voltage information and evaluates the voltage samples to determine amount of time sensor voltage is out of range. If HO2S voltage is out of predetermined range, DTC will set.
Conditions required to test for DTC are:
  • No ECT, IAT, MAF, MAP or TP sensor DTCs set.
  • No EVAP system DTC set.
  • No other DTC tests in progress.
  • No device control active.
  • System voltage measures at least 9 volts.
Diagnostic Procedures
  1. Perform ON-BOARD DIAGNOSTIC (OBD) SYSTEM CHECK. See the BASIC TESTING - 4.3L article. Retrieve and record FREEZE FRAME and/or FAIL RECORDS data for each DTC set. Go to next step.
  2. Start engine and allow it to reach operating temperature. Place gear selector in Park or Neutral, and apply parking brake. Increase engine speed to 1200 RPM. Using scan tool, read HO2S BANK 2, SENSOR 1 voltage. If voltage is less than 0.086 volt, go to next step. If voltage is not less than 0.086 volt, go to step 4).
  3. Turn ignition off. Disconnect HO2S connector. Connect a jumper wire between HO2S harness connector ground circuit and chassis ground. Turn ignition on, engine off. If voltage is 0.35-0.55 volt, go to step 7). If voltage is not as specified, go to step 5).
  4. DTC P0137 is intermittent. If any additional DTCs are set, diagnose affected DTCs. If no additional DTCs are set, see DIAGNOSTIC AIDS.
  5. Check HO2S sensor harness connector signal circuit for short to ground. If short is found, go to next step. If circuit is okay, go to step 8).
  6. Repair circuit as necessary. After repairs, go to step 9).
  7. See DIAGNOSTIC AIDS.
  8. Replace VCM. Program replacement VCM using required equipment. After replacing VCM, go to next step.
  9. Using scan tool, select DTC, CLEAR INFO function. Start engine and allow it to reach operating temperature. Using scan tool, select DTC, SPECIFIC function and enter DTC P0137. Operate vehicle within conditions required to set DTC. If scan tool displays RAN AND PASSED, go to next step. If scan tool does not display RAN AND PASSED, return to step 2).
  10. Using scan tool, select Read and Record INFO, REVIEW INFO function. If any undiagnosed DTCs are displayed, diagnose affected DTCs. If no DTCs are displayed, system is okay.
Diagnostic Aids
Using scan tool, observe LT FUEL TRIM values at different RPM. If conditions to set DTC P0137 exist, value should be about 158 or greater. Check for an intermittent short to ground in HO2S signal circuit. Never solder HO2S wires. Check for fuel contamination. Check for proper fuel pressure. Check for exhaust leaks.
Old Apr 26, 2010 | 01:12 PM
drin's Avatar
2002 chevrolet blazer 4 door, 4 wheel
Old Apr 26, 2010 | 01:37 PM
drin's Avatar
OK IM DUMB, sorry i simply forgot to reconnect a vacuum line by my throttle body when i cleaned my throttle body.
Old Apr 26, 2010 | 01:41 PM
Hopefully that was it! Let us know if you need further assistance.
Old Apr 26, 2010 | 02:00 PM
drin's Avatar
yeah im hoping so, the trouble code will clear by itself if the problems fixed right?
Old Apr 26, 2010 | 02:10 PM
If the problem is no longer there, then yes, the light will clear itself in time. To coax it along, you can disconnect the battery for 10-15 minutes.
chesthing
14
Dec 4, 2013 08:02 AM
Kilo
Jul 27, 2013 06:57 AM
Supercity
Jul 10, 2011 01:23 PM
KA3AX
May 9, 2006 08:38 PM
swartlkk
Apr 24, 2006 02:37 PM
