passenger side window problem
Could be dirty but more then likely youhave a bad master window switch, Have you checked the plugs on the bottom of the master switch to see if any wire's may have come loose? How abouta voltage check on it?
Remember every time it's rainning outside and you open up your drivers door, a lil rain get's inside those switches...
the master switch for the windows can be found in the help section of any auto store. these are very common to go, so they should have them. 99% of the time it really is just a bad switch. which run about 50 bucks, so i would pick it up as well as a voltometer(probably will come in handy later in life).
upmaine
Jul 9, 2012 12:31 PM
408blazer
Jun 9, 2012 11:04 PM
burt
Sep 2, 2008 02:15 PM
hillbillyinOhio
Jul 12, 2006 04:18 AM
