quick 4wd ?..hopefully
I could be wrong...will be the second time in my life, haha. Anyway, I dont think the hose I found was simply plugged into something to block it..like I said, I could be wrong..
But I feel like it was hooked to something...just dont know what?
Thanks guys.
-HP
Thanks guys.
-HP
The reservoir is buried in the fender. You won't see it. No doubt the line coming from it fell into the fender when it fell off. I suggested blocking it off as something to try. The vacuum comes from the motor and goes to 4 things thru hoses and T-fittings: AIR pump actuator valve (your first pic under the battery), 4WD actuator solenoid, heater controls, and the reservoir (just a plastic ball with a fitting and hose) which "evens things out" so when you get on & off the throttle you heater doors don't move and the 4wd doesn't disengage.
Ok, all I got is black hands from the ****.
I tried to plug the hose up, sealed it; no air.....When I did that, nothing changed, at all.
Thanks for the picture, but it didnt help me at all. I don't know if it's the year difference in models, but i went out there and looked around on the fender and everywhere AGAIn and still couldnt find anywhere for the hose to go. I took my laptop out there to look at the picture to find that on my blazer, couldnt relate the two.
Any more suggestions??
- HP
- HP
I also have the mystery hose. it has been hooked up to something, because the end of the hose is spread out where it has been on a fitting. I unbolted the fuse box and the thing that all the brake lines go into, and I see no where it can go. But it is sucking air hard, theres no way my acutator can pull that cable with that much of a lack of vacuum. I need help oooo bad
Ok, after reading a lot of other posts, the mystery hose goes INSIDE the driver side fender. while taking everything apart I noticed a black plastic cover on the fender
, next to the abs. there is a Vacuum RESERVOIR in there, supposedly a little ball with a fitting for the hose on it. It has to go there, I dont think there is anywhere else at all it could go, its too short. I live in TN, im going to try it very first thing tomorrow, i got a good feeling!
I hear ya Combs. I am going to try and do the same thing in the morning. My problem is, I cant seem to find where the hose actually goes. I keep hearing about this resevior and that the hoes NEEDS to go there...
haha, I just cant find where that hole is, it's driving me mad.
-hp
-hp
