Rattle / clunking noise
#22
RE: Rattle / clunking noise
Hey Kyle, what way does the washer go?? I know it goes on the BOLT side but facing what way??? My truck was missing both washers so I bought the pack of 2 from the dealership. Thanks in advance.
#26
Wow!!! I can't believe it REALLY works!!! I have a slightly bent rim (which cant be balanced) and at highway speeds it made my truck clunk and clunk and now NOTHING of courseth truckstill shakes but no clunk!!!
#27
could have saved $400
Check your hood hinges. This is a common noise and does sound exactly like a loose shock or bad ball joint, only higher up. It's very difficult to tell the difference.
Toss a rag under the corners of the hood near the hinges. Careful not to wad it up too much and bend the hinge, just enough to put some tension on the hinge bolt. If this stops it, then you'll need to go to the dealership and get two (2) of PN 12383460. Remove the hinge bolts, put the washer onto the bolt and reassemble.
#28
My clunking is coming from the right rear. I swear it is coming from the interior, so I pulled every panel off from the inside and found nothing that could be causing this loud clunk. It only happens at low speeds and sounds like it is coming right from the rear wheel well. Anyone have any ideas on this? I've messed with the exhaust and it is solid and doesn't seem to be causing the noise.
#29
#30
I complained about that for awhile until someone said "well, you could pay about $30k for a new truck..."
v8colorado
04-05-2011 08:01 AM
Blazin 4x4
10-23-2005 06:11 AM
kwsrv@libcom.com
09-07-2005 05:01 AM
