Really need your help
Old Sep 3, 2009 | 05:03 PM
Confuused69's Avatar
Confuused69 is on a distinguished road
Default Really need your help
I have looked for hours....... I replaced my fuel sending unit on my 95 jimmy 7 days ago. After I put it all back in and got the fuel tank back up and mounted, I tried to start my truck. And the fuel pump made this weird winding noise. So.... I pulled everything back out, and put on this thing called a pulsator that i took off because it looked like it was pointless on the fuel pump. Then I put everything back up and mounted tank. Then the pump wouldnt engage, so I thought the pump was crap, so I finally put new ac delco in today, and guess what..... It does not engage. It doesnt frikin work.... I checked the relay, and its working.. Is there a fuse for my fuel pump? I really need my truck running, i cant believe its been sitting for 7 days now. Please help.
Old Sep 3, 2009 | 06:19 PM
rriddle3's Avatar
Realizing that there are probable differences in the fuse set-up between your year and mine, in the underhood fuse box on the driver's wheelwell, the ones labeled 'ECM B' and 'IGN C' are for the fuel pump. If you have an owner's manual for your truck it will show the fuse layouts for it. Have you also verified the fuel pressure with a gauge?
Old Sep 3, 2009 | 07:06 PM
No I havent.... Im just trying to get the fuel pump to actually sing. I know theres no fuel coming because when i take the fuel lines off of the sending unit, they are dry. Im actually thinkin the connector is bad.... But I gotta charge my battery now cuz i killed it during trial and error... Never ends. And There isnt a fuse box under the hood in my truck, unless im stoopid. I stared into my engine bay for 10 minutes trying to find one lol.
Old Sep 3, 2009 | 10:23 PM
terry s's Avatar
terry s is on a distinguished road
Look carefully at the plug that connects to the pump. The connectors have a reputation for coroding and not making contact. They sell a replacement connector with pig tails at the auto store if you need one. If you replace it solder & heat shrink the connections. Do not trust crimp on connectors as they may corode after moisture gets to them.
Old Sep 3, 2009 | 10:48 PM
ahhh yes.... I forgot about that.... No wonder why when i got the pump the dude at advance said "you wanna get the wiring harness with it?" I said, what do I need that for, and he says "i don't know, the computer said so." Haha ill check that **** first thing in the morning!
Old Sep 4, 2009 | 01:25 PM
fixed it!!!!! Damn connectors.
Old Sep 5, 2009 | 01:57 AM
terry s's Avatar
I'm glad it worked for you.
serrasalmus
Jun 12, 2012 05:57 PM
Kage0113
Oct 27, 2008 12:34 AM
sindy1232
Jul 25, 2008 11:59 AM
vicskim1
Jun 19, 2007 10:53 AM
boomtruck97
Aug 15, 2006 10:21 AM
