really stupid....
#41
NAPA Belden wires (dark blue) and cap/rotor are good ones. I've got em on mine, my friend Ryan and his dad use them on theirs. No problems with them. Always use AC plugs though.
#42
I don't know about the cap since I only use GM parts since I work for a GM dealership. The display could be signs of a cluster going bad I think. Is the fan type noise coming from the right or left side of the dash? and the last noise sounds like your exhaust system makes noise as the metal expands and contracts with the heat.
The fan type noise comes from the middle, where the cd player and all that are....
Also CNYcountrykid, thanks....I will check those out.
#43
OKKKK I had my fuel pressure tested and its at 50...I said thats low, my guy said no, thats normal...I said I dont think it is!
He gave me the pressure tester t borrow to check it when its cool and having the issue....I said so if it is low then what, he said New fuel pump.....
I am starting not to trust him....what do you guys think? 50 IS low, right?
#44
If you're talking about key on, engine off pressure then absolutely too low. Work through the steps in 96+ Fuel System Diagnosis
#45
i would try to isolate that p0300 misfire to a single cylinder, or left or right side engine banks, or random multiple cylinders by using a scan tool. Then you'll know what cylinder(s) to focus on. For instance say you had a misfire on cylinders 1,3 and 5. then i would look at what controls that side, I.E. o2 sensor, or leaking intake gasket. but first try to find the cylinder(s) first. It may only be a bad spark plug or wire.
#46
Thanks, I will do that.....this is frustrating.
And no it was Engine ON...running.
OK, just went out and checked the pressure with the key on, engine off.....starts at 60 and goes down to 50.
#47
Did you use the link rridle3 showed you to diagnose your fuel pressure ? It all takes time and patience.
Hopefully you can eliminate some parts replacement by following the diagnosis steps.
#48
yeah, been looking at that....its odd though in the morning when its having the problem, the pressure is maybe 3-5 points higher.
I have some plans.
I have some plans.
#49
Okay, Well, remember the hammer !
#50
HA HA, yes....if this doesn't work you can ship it on over!
and BTW, thank you guys!
ivannj
01-06-2006 08:09 AM
psawatsky
08-06-2005 01:48 AM
