Rear hatch won't open
Old May 1, 2019 | 12:00 PM
Bayla's Avatar
Bayla is on a distinguished road
Default Rear hatch won't open
1995, Jimmy. The rear hatch lock has power (I can hear it click). I can't find a way to open the top (glass hatch) so I can repair it? Any Ideas??? every thing I have seen you have to have gate down to remove panel to access lock?
Old May 2, 2019 | 07:54 AM
cleburne red's Avatar
No, search again. There is a slot on the inside of the tailgate, you can slide a flat head in to manually move the mechanism to open the glass. You might have to peel the carpet back to find it.
I know there's a thread on here somewhere that has pics of it
Old May 2, 2019 | 08:54 AM
Bayla's Avatar
Thanks for helping, I looked up The slot your talking about.... not sure how to get to it with glass door and gate locked closed? Is there an access panel under carpet? when I pull on door panel feels like it will break before I get Clearance under the "Hump" where slot is? Trying not to cause unnecessary damage...I'm good at that lol How would you do it?
Old May 2, 2019 | 09:31 AM
rriddle3's Avatar
You have a broken hatch actuator. There are plenty of threads concerning the repair procedures. "Search' function is your friend.
Old May 2, 2019 | 09:40 AM
You access it from the inside. You need to be in the rear cargo area, and pull down the carpet a little, and there is a slot. I had the same problem on mine, I marked the location on the carpet with sharpie, on case I had to get to it again. When I get home, I'll look and post a pic, until then, I'll try to find the thread on here
Old May 2, 2019 | 07:10 PM
Bayla's Avatar
Default You rock!!
You Rock!!! That was the “pear of wisdom” I was looking for!!!!
Old May 2, 2019 | 07:52 PM
You get it open?!
Escalazer
Aug 12, 2012 09:31 AM
Jace1217
Feb 22, 2012 03:55 AM
Hollywood2010
Sep 21, 2011 05:51 PM
Major Tom
May 23, 2011 12:34 PM
jnunez
Mar 25, 2010 01:57 PM
