rear windshield fluid pump mystery
I know this thread is old but I had the same problem. The pump would turn but only sometimes and it was too slow to push fluid to the back.First I pulled the pump and put jumpers on the posts to check if pump was working. It was good. Them put test light on plug and noticed the light was weak and sometimes didn't come on. Then I took the switch out of the dash and opened it up. There are two small contacts inside. One each for the wiper and the washer. I cleaned both with the end of a screw driver. Works good now.
Both of my pumps (Front and Back) are in the fluid Res under the hood. The thing you put blue water in. Its a lot longer then it looks. Once you pull it out you will see both pumps, just replace the one you need to and check your lines to make sure they aren't all dried out and leaking.
joshua_andrew92
03-18-2010 03:01 PM
Matty Kling
10-10-2007 01:25 PM
carlo
01-01-2007 03:03 PM
kaindragoon36
03-25-2006 04:22 PM
