remote locks
Old Feb 12, 2011 | 12:28 PM
gregl316's Avatar
gregl316 is on a distinguished road
Default remote locks
How can i tell if I have remote locks? I didn't get a fob but it does have power locks and it is a LT.
Old Feb 12, 2011 | 05:05 PM
LRV31's Avatar
LRV31 is on a distinguished road
Check the decal in the glove box and look for option code AU0. This is one of the option codes for the Keyless Entry.
Old Feb 12, 2011 | 05:24 PM
UberFail's Avatar
UberFail is on a distinguished road
^^^ what he said - btw info regarding your blazer could and would help for some of us to give u the right steps to program a new fob to it.
Old Feb 12, 2011 | 06:52 PM
gregl316's Avatar
Default no sticker
that sounds easy but someone took the sticker off. now what?
Old Feb 12, 2011 | 11:39 PM
UberFail's Avatar
what year do you have? you can try the steps to reprogram a FOB to it and see if it cycles the lock system. i suspect this would confirm you do in fact have the remote option.
Old Feb 13, 2011 | 11:13 AM
LRV31's Avatar
You can check to actually see if you have the Keyless Entry Control Module in your Blazer which is located under the dash. I know someone mentioned its location on here before.
Old Feb 13, 2011 | 11:21 AM
gregl316's Avatar
Sorry its a 96. I read the link befor on programing a fob but I'll be damned if I can find it again. Could you please post the link in your reply.
What does this module look like and where exactly is it?
Thanks
Old Feb 13, 2011 | 03:09 PM
LRV31's Avatar
Thanks
The module is under the dash on the driver's side for some years. I don't know if it is there on the 96.
One method to program the remote is:
Hold down the driver's side door unlock switch. Make sure the door is closed.
Turn ignition ON-OFF & again ON-OFF then release door switch. The doors should automatically lock & unlock. This shows the system is in programming mode.
Hold down both lock & unlock buttons on the remote fob until the doors lock & unlock automatically.
Turn ignition back ON & the remote should be programmed.
Old Feb 13, 2011 | 06:46 PM
UberFail's Avatar
if that method fails, because its a 96 and does not have the BCM in it, you can also connect pin 4 and pin 8 on the obd II reader to cycle the remote lock system.
but here's the all in all link for the RKE system.... (reprogramming, finding the RKE module and some other items)
https://blazerforum.com/forum/tech-articles-diy-29/rke-remote-keyless-entry-fob-programming-info-10176/
hollywoodgrad
Jan 26, 2012 05:36 AM
ComputerNerdBD
Oct 16, 2011 06:10 PM
stevo
TrailBlazer GMT360/GMT370 (2002-2009) Tech
Aug 1, 2009 03:09 PM
audio
Jul 23, 2009 08:49 PM
NTL1991
Jan 13, 2009 11:28 PM
