Removing headlights.
Old Jun 4, 2008 | 07:30 PM
elementalnature's Avatar
elementalnature is an unknown quantity at this point
Default Removing headlights.
I am assuming that a Jimmy is the GMC version of the Blazer. So therefore I have come in search of knowledge. The Jimmy I am looking at is a wreck. Needs a good detailing and I have plans to follow the de-oxidizing headlights procedures but I need to know where to start with removing the headlights. Any help could be of assistance. Thanks
Nathan
Old Jun 4, 2008 | 07:39 PM
getonerd's Avatar
getonerd is an unknown quantity at this point
Default RE: Removing headlights.
i think their is two clips for each light but thats for a blazer just pull up on them
Old Jun 4, 2008 | 07:52 PM
Yeah, there are two plastic clips per side that are located behind the radiator core support. Pull up and they will release the light, then you have to tip the top edge of the light out and pick up to disengage the tabs from the slots in the core support. Disconnect the wiring and it'll be free.
Well, that is for any '98+ Jimmy anyway... Not too sure on the '96-'97...
Old Jun 4, 2008 | 08:26 PM
Well I'll let you know something tomorrow. I'm picking it up and heading to work after picking it up. I'll be sure to take before and after pics :O
Old Jun 4, 2008 | 08:29 PM
Davis83's Avatar
Davis83 is an unknown quantity at this point
96 is different. Book says to remove battery and air cleaner box for access from the back - pain in the butt.
However easiest way is to remove the grill and unbolt the light assembly'sfrom the adjustment frame -they will fallforward into your hand. Out and back in takes about 30 minutes.
Old Jun 4, 2008 | 08:44 PM
Sounds easy. Steps for removing the grill?
Old Jun 4, 2008 | 11:31 PM
mdehoogh's Avatar
Old Jun 8, 2008 | 12:07 PM
jukdd's Avatar
jukdd is an unknown quantity at this point
if it's a 94 just look for the screws, they aren't hard to find on the grill, open the hood to, there is someon the top i beleive.
hollywoodgrad
Jan 25, 2012 01:58 PM
beantowner25
Dec 28, 2009 12:28 PM
Crestwood1001
May 31, 2009 10:45 PM
Annekat91
Feb 13, 2006 07:42 AM
sunnyc123abc
Sep 9, 2004 04:59 AM
