removing transmission pan from 99 Blazer
Old Jan 20, 2007 | 12:43 PM
dmndeacon's Avatar
dmndeacon is an unknown quantity at this point
Default removing transmission pan from 99 Blazer
Can someone tell me what this device is and how it's best removed when accessing transmission pan bolts? THANKS!
[IMG]local://upfiles/4899/3F1CB4A56EF24240A27AE41C6C6AEA2E.jpg[/IMG]
Old Jan 20, 2007 | 12:46 PM
Default RE: removing transmission pan from 99 Blazer
You can remove the shift cable from the linkage on the end to the left of what is shown in the picture, then I believe you remove the metal clip that is to the left of the bracket on the plastic mount attached to the cable. This should allow you to pull the cable out of the bracket. However, when I did my trans service, I was able to get a 1/4" drive socket past the cable to remove the bolts. I used a short socket with a swivel and got the bolts out fairly easy. If you have trouble initially, you could use a wrench for the first bit, then once you are able to twist the bracket for more clearance, use a rachet.
Good luck
rigdog
Nov 22, 2010 11:03 PM
rigdog
Nov 22, 2010 02:42 PM
dmc919
13
Mar 29, 2010 11:16 PM
blazerJim1701
Aug 28, 2009 11:50 PM
bigwes
Jan 20, 2009 01:00 PM
