Replacement Key FOB
#31
i just ordered a pair off ebay from remoteremote.com and it was simple to program hold lock down turn key on off twice end in off.. locks cycle to say learn process is active hold lock and unlock on fob wait for lock to cycle do this for all fobs then when done turn key on to initiate end of re learn.. test all fobs. this was for a 04 2 door blazer
#32
Ok..I have tried twice already and did not work. One of the steps above says after you turn the key off and on 3 times and release the unlock button the lock unlock cycles to indicate it goes into program mode. This does not happen i dont think it is going into program mode. I really suspect the new ignition cylinder.
Not sure what to do next. Going to try again soon. At least it was only 6.99 +shipping
Regards
Regards
#34
Hold down unlock on door
Turn key on/off 3x ending in off position
Release unlock button on door
Hold down lock/Unlock buttons on fob simultaneously for 15seconds plus
Nothing happens
#36
Hi Don both times I have held both buttons down for a minute +. There is a little LED light on the FOB that is quickly flashing red like it is trying to communicate but so far nada. I have read I believe on this forum that "FOB's are like children and some learn faster than others. Will keep trying and see what happens
regars
regars
#37
Hmmm.... I got a 99 blazer, and my fobs dont have a little light. The wifes sonoma is an 02 and doesnt have a light either. Wonder when they had them, or if it was a location thing.
4 door blazer with hatch release. Same as 2 door blazer with hatch release.
Front of blazer fob
2 door sonoma without hatch release, same as s10
Front of sonoma
Front of blazer fob
Front of sonoma
#38
DonL
Mine(old and new) look the same as your 4 button FOB. The exception is that the button that is labeled "REAR2x" on yours is labeled "GM" on mine. I really have no idea how the old button on the argininal FOB was labeled it has faded off now The part numbers on the back are different too. The Part numbers and he FCC # match the original one I have that came with the blazer 20 some odd years ago.
Thanks for your help
DonA
DonA
Shauniscool123
01-06-2020 07:00 AM
