rev limit
I have a 2000 blazer and if i try to do a burn out just by using the brake, it will only rev up to 2000 rpms. is there any way to make it rev higher or is that in the computer?
no one has anything to say, also its a automatic
Pretty sure that's the computer bro, whenever I power brake my '87 it will burn the hell out of 'em. It will shift through 1st, 2nd, 3rd, and 4th on its own.
not mine, when i try it it will rev up to 2000, and then just take off without ever loosing traction. it sucks
mine is like lolo's it will burn like no tomarrow, unless in 4wd then it just pushes.
chris
chris
damn, mine is only 2wd though
my little 2.2 in my 01 noma stick will smoke the hell out the tires. it sounds like you got traction control, but i didn't think that blazers offered that option. is there a TCS button on your dash or center console? or does a traction light come on when you do it?
no there is not traction control on it, it just wont rev high enough to do so.
Sounds to me like it's just hooking up at 2k and leaving. Not a rev-limiter problem, your brakes just aren't holding it according to this:
i have a 95 blazer with several eng mods but the computer combind with the torque converter setup for towing wont alow it to go over 2000 rpm unless i get the tires to break los before it limits the throtal position then it will burn the hell out of them
bigjohns96sport
11-26-2009 09:57 PM
