start up problems again
Old Feb 27, 2014 | 07:18 PM
  #31
Does the grey wire drop to zero after 2 seconds?
Purple wire is reference voltage from the PCM, a tad high, but it is what it is.
The 2 black wires: Need to know resistance to ground, not voltage. DVOM probe on one wire, and the other probe to chassis ground. Check both black wires the same way.
Black probe to chassis ground and red probe to black wires, voltage should be zero.
Old Feb 27, 2014 | 07:34 PM
  #32
shane caines's Avatar
shane caines is on a distinguished road
grey wire does drop to 0 after 2 seconds both black wires are 0
Old Feb 27, 2014 | 07:37 PM
  #33
Ohm meter on lowest range possible, then test resistance to ground.
Old Feb 27, 2014 | 07:55 PM
  #34
I will have to get an ohm meter tomorrow i was using a voltage meter i thought it would work for both. (my stupidity) will post results when complete
Old Feb 27, 2014 | 08:14 PM
  #35
Ohms is how much resistance there is through a wire. The lower the better. If a wire is partially broken, corroded, or there's a poor connection, it will have high resistance. The higher the resistance is, the less efficient the load, (fuel pump in this case) will operate. If the wire is completely broken, resistance will be infinite, and the load will not operate at all. In your case, we're suspecting higher resistance, but not infinite because the pump at least works. Probably a poor connection somewhere, and hopefully the pump works properly after you soldered the connections. That might be all it is/was.
If fuel pressure is still not good, the next set of tests, before the tank and pump go back in, is Voltage Drop Testing
Old Feb 28, 2014 | 03:48 PM
  #36
did the ohm test, wasnt sure if key was to be on or off so i did both. Key on were readings of 7.91 and 11.13 and with the key off readings were .09 and .26
Old Feb 28, 2014 | 03:55 PM
  #37
Key off readings are what we needed, and they are good. Plug the connector back to the module and test fuel pressure and leakdown, at the fuel filter would be good. Post the results.
Old Feb 28, 2014 | 04:02 PM
  #38
k key on and no boosters hooked up it was 58 psi and with booster on battery was 65 psi obviously too low
  #39
test was done at the fuel filter
Old Feb 28, 2014 | 04:36 PM
  #40
If the voltage drop test that you did in post #20 was good when tested at the fuel pump, both ground and positive, then the fuel pump is faulty. There are two connections inside the pump module. The wires run from the module connector to the fuel pump motor, if either of those connections is poor, (might be worth checking) it should have shown up on the voltage drop tests... if they were done correctly Also check the short rubber hose from the pump motor to the module for fuel leaks. If all that stuff checks OK, replace the pump.
