Thoughts on radiator "Stop leak"
Hello all
I have a 98 blazer 4x4. Lately ive noticed the heads seep a touch of antifreeze around the front part of the engine. I know its not the intakes because thoes have just been done. I verified this by looking closely with a flashlight. Anyways ive been thinking about using stop leak to plug the leak and I was wondering what testimonies some may have about the stuff. I would use"Bars" tablets if I were to go with something. Does the stuff work well? will it plug up my heater core or radiatorand reduce cooling capacity? or should Ijust leave it be? I just have a pet-peave about leaks- especially coolant.
RE: Thoughts on radiator "Stop leak"
Try the Bars that comes with the little pellets inside of a liquid. That's what i used on my truck and it actually stopped my intake gasket leak.
GM sends the blazers out with a small amount of Bars stop leak in the radiator from the factory, that's what that brown residue is in the coolant tank.
i would check your radiator for any cracks as well... i had the same problem and put some stop leak in and then i found a crack near the top on drivers side... costing me a leg to fix it
I would not put stop leak in a cooling system; could have adverse effects...I would just repair or replace as required. I know this from experience....
You wouldn't put masking tape on a water leak?? Especially the cooling system....JMO
I've used Bar's leak in several of my cars over the years - always with good results (although we all probably agree it's just buying time). I would trust it...no experience with any of the others.
Alright thanks for your input guys! I think im just going to leave it be and keep an eye on it. Its been 3 or 4 months since ive topped off the coolant and its still slightly above the "full" mark
Just a little info on BarsLeak, this product is installed at many automobile production factories, ( yes I didnt believe it to be true either) also farm machinery and other products , I will check my source on this and post the info.
O.K. here is the info , type in the term quasimotors saab 9000 site , then click on links, then click on Bars leak page, this is interresting reading.
kevin turner
04-09-2010 01:21 PM
bigdaddykane93
01-04-2010 12:03 PM
burak sozer
11-30-2008 04:38 PM
