Trans oil cooler
Old Mar 9, 2014 | 02:47 PM
schrack's Avatar
schrack is on a distinguished road
I rum B&M super coolers on all 3 of my dimes. Way better made than the hayden you buy at local parts stores.
Old Mar 9, 2014 | 07:50 PM
The key with any trans cooler is to get plate & fin design, not the "economy" tube & fin design.
Old Mar 9, 2014 | 08:14 PM
JavierEscalonJr's Avatar
JavierEscalonJr is on a distinguished road
Captain Hook isn't it recommended to connect the external cooler first then run to the radiator depending on the area you live?
Old Mar 9, 2014 | 09:01 PM
The point of having an add-on cooler is to cool the fluid as much as possible before it enters the transmission. Installing the cooler in the return line cools the fluid before it enters the OE cooler in the radiator. The OE cooler would increase the fluid temp to engine coolant temp, which defeats the purpose of the add-on cooler.
When the engine is at operating temperature, (~198F) using just the OE cooler, trans fluid entering the transmission would be slightly less, and would increase if the engine were to overheat. Transmission fluid life decreases dramatically as fluid temperature increases, so there isn't much room for error. The add-on cooler gives a little "room for error" and by eliminating the OE cooler, if the engine overheats, the transmission in unaffected.
Old Mar 9, 2014 | 11:06 PM
The OE cooler does not increase the transmission fluid to thermostat regulating temperature as it is located in the 'cold' tank of the radiator. An infrared thermometer can be used to get an idea of what it is currently running.
Going back a few years with my '00 Bravada, I had installed a B&M Supercooler prior to the factory in-radiator cooler and saw ~190F temps in the return line to the transmission while towing on a 85F day. Prior to that it was up near 230F which the passenger side radiator tank was only around 160F.
Another thing to remember is that too cold means that the fluid will not boil off any moisture which will degrade the fluid properties as well. Coolers with either an external or integrated thermal bypass work the best. For a cold climate, plumbing the cooler in before the factory cooler does give faster warm up times in my experience.
Old Mar 10, 2014 | 10:32 AM
LannyL81's Avatar
Sure appreciate the information; looking at getting one of the B&M Supercoolers, trying to decide which one, the 70255 or the 70264: the difference is in the thickness, one is 3/4", the other 1.5" thick. Not sure if there would be a clearance problem with the thicker one or if the 3/4" is adequate for my vehicle use; no plans of doing any towing, but definitely not living in a cold climate here in Tucson, AZ.
Suggestions?
LesMyer
Dec 10, 2014 10:49 PM
nascar2496
Jan 18, 2012 10:48 PM
DaleA
Jan 7, 2009 06:54 AM
shooter2499
Feb 4, 2008 09:23 PM
Jetfixer
Jul 11, 2006 05:02 AM
