Transmission Cooler
Old Apr 10, 2013 | 10:02 PM
Klturi421's Avatar
Klturi421 is on a distinguished road
Default Transmission Cooler
This weekend I am going to be pulling my engine. I had a couple of questions in regards to the transmission cooler:
When I pull the lines off of the cooler, will the transmission fluid drain from the lines and out of the transmission itself? If so is there a way to keep that from happening?
Any Suggestions?
Old Apr 10, 2013 | 11:42 PM
gitch93's Avatar
gitch93 is on a distinguished road
if ur pulling the engine ull only have to dissconect the lines off the radiator. u will loose some fluid but u can cap it off with a rag or tape.
Old Apr 11, 2013 | 06:46 AM
Twip's Avatar
the ends of the tranny "cooler" lines are higher than the transmission so you wont lose much at all. just make sure that you check everything when you are ready to start it back up after the re-install.
stevelknievel
Apr 29, 2007 05:34 PM
broke33
Mar 18, 2007 08:03 PM
ivannj
Sep 15, 2006 08:25 PM
jagblazer01
Sep 6, 2006 11:08 PM
Jetfixer
Jul 11, 2006 05:02 AM
