trouble removing hitch recever
Old Feb 10, 2010 | 11:30 AM
SPLjimmy's Avatar
SPLjimmy is an unknown quantity at this point
Default trouble removing hitch recever
ok so i have a 2 inch hitch with a reciver stuck in it right now.... i have used heat, a hammer, more heat and bigger hammer and it will not budge an inch. tonight when i get out of work im putting the DeWalt sawzall on it cutting it off then try to cut it length wise into the hitch anyone have any better ideas. any help is apprecited THANKS!!
Old Feb 10, 2010 | 11:47 AM
Spectreblazer's Avatar
Banned
Spectreblazer is on a distinguished road
hook on to it with another vehicle and pull it out while you are in neutral with your foot on the brake
Old Feb 10, 2010 | 01:12 PM
AJBert's Avatar
Patience...and a LOT of PB Blaster.
Spray it down, let it set for a day, spray, set, spray, set, etc. Do this for a week or so, then break out the BFH.
Old Feb 10, 2010 | 02:11 PM
terry s's Avatar
terry s is on a distinguished road
Are you positive that part of the hitch pin is not still in there?
Old Feb 10, 2010 | 04:35 PM
ABN31B's Avatar
x2 on double checking it is in fact un-pinned and ready to be pulled free.
then x2 on the PB blaster. soak that pig from every angle
hammer it in, hammer it down, hammer it out, put a jack under the tip and lift it up a bit.
then pb it again and got to town with the sledge. you could try the "chain it to the old oak tree" method, but i would just beat and blast. it will come out eventually
Old Feb 10, 2010 | 06:37 PM
neo71665's Avatar
I agree on checking the pin. Some pins are dual sized and use a sleeve to make it bigger. You might have removed the smaller section and the sleeve is still in there.
Old Feb 10, 2010 | 08:59 PM
SPLjimmy's Avatar
i know what your talking about with the pin but this isnt the case my brother owned the truck before me he left the reciver in for about 3-4 years in upstate NY not a good idea i tried the jack too but ill let PB soak in it
Old Feb 11, 2010 | 08:35 AM
richjoe's Avatar
richjoe is on a distinguished road
my ball hitch has been on the blazer for about 10 years. i hate to think what I will have to go through!! I remember Christmas shopping one day and thinking I should remove it for the winter. Same day I was rear ended (@1-2 mph), and did not suffer any damage. That was the last time i thought about removing it.
Dabber
Dec 21, 2006 02:22 PM
S10Blazer
Oct 9, 2006 11:45 PM
dustinm417
Engine & Internal
Jul 18, 2006 01:54 AM
1996BZR
Jul 8, 2006 12:59 PM
BlaZeR FXB1581
Jan 15, 2006 05:24 PM
