Trying to get 4wd working on new 2 me 97
Old Jan 19, 2011 | 02:56 AM
ark steve's Avatar
ark steve is on a distinguished road
Default Trying to get 4wd working on new 2 me 97
Just got a 97 blazer, old owner put in a used eng/tranny about 1 1/2 yr ago, and 4wd stoped working about the same time. I have found and repaired: vac supply hoses off, damaged, and open tees, vac hose off acuator, dash switch broken. I'm to the point the button engages/transfer case, and in 4wd I get good vac to the hose for the acuator, when switched to 2wd the supply of vac stops, but it holds vac untill I open the hose to release it. I was worried about connecting the hose, and havn't touched 4wd with it on. There is a capped off tee in the hose going back forward from the vac switch on the transfer case, but I can't find where it should go. Is there an elect switch to release the vac? How much damage would it do if drove it with the ft engaged and the trasfer case dis-engaged? They are talking snow again, and where I like it takes 4wd to get in/out.
Thanks.
Steve
Old Jan 20, 2011 | 02:19 AM
ark steve's Avatar
Update. Looks like that part is fixed? I jacked up a ft wheel, and turned it by hand. It turned in 2wd, engaged in 4wd, and could turn it again after pushing 2wd again. I couldn't find where the hose is supose to go but looks like it's working.
big_charms@hotmail.com
Mar 20, 2014 10:26 PM
Druubin
Mar 10, 2010 09:40 PM
chevyman4L
Oct 20, 2008 09:58 AM
artsound
Jan 26, 2008 09:39 PM
Blazinchevy01
Tires and Wheels
May 26, 2006 09:30 PM
