Turn signal relay
Hi,I have a 2000 Blazer,i can hear my turn signal relay on all the time making the blinking noise except when i apply the break it goes off the turn sigs work but the blinker noise is driving me crazy,i replaced the relay today now when i turn the key its a buzzing sound,do i need to replace the whole turn signal unit odoes someone have a fix? Until then music is turned up.....
OK the correct name is the thermal flasher is what im hearing? not relay
![Icon Shrug](https://blazerforum.com/forum/images/smilies/icon_shrug.gif)
Thanks for the info,but I fixed the problem using this and saved 300.00 on a new part.
http://www.automotiveforums.com/vbul...d.php?t=577320
P.S.if anyone ever has this problem with your multifunction switch,try the above first,it really worked for me and can save you $$$$ When I took mine apart I first sprayed it with CRC electronic cleaner i mean soak it good to get all the old grease and dirt out then clean it with q-tips...fixed
Last edited by swartlkk; 04-14-2010 at 01:32 PM. Reason: *Combining Consecutive Posts* - Please use the EDIT feature to include additional information in your post if another member has not yet replied.
SubbinBlazer
05-24-2013 12:56 PM
ta3ff
10-14-2009 05:07 PM
bestes
05-31-2008 03:16 PM
VW Petrolero
06-18-2007 06:40 PM
shaka1111
02-13-2006 02:23 PM
