turn signal trouble
Old Mar 7, 2006 | 03:26 PM
sumunabeech's Avatar
sumunabeech is an unknown quantity at this point
Default turn signal trouble
Okay, I've searched all over here but i haven't seen my exact problem
First of all, I have a '97 2dr. LS. All four markers will light up, so the bulbs are okay. The problem is when I first start the car. First turn, the signals work. Second turn, they flash slow, then fast, then slow, etc. Third turn, they will stay on when I try to use them. This happens every time I restart the vehicle. I'm cornfused, since fuses and bulbs are good.
Help!!!
BTW, I am new to Blazers but not to cars by any means.
Thanks
Old Mar 7, 2006 | 06:32 PM
tomsblazer's Avatar
tomsblazer is an unknown quantity at this point
Default RE: turn signal trouble
Could be the flasher module going out.
Does the blinker rate slow with each turn of the steering wheel or with each activation of the turn signal?
Old Mar 7, 2006 | 07:52 PM
ORIGINAL: tomsblazer
That's what I was thinking too, but I don't have a Chilton's yet to let me know where the module is.
EVERYTIME I turn on the car it works the first time, albiet slowly. The second time I try, it flashes slow, fast, slow, fast... Third time, solid like a bulb is out.
Now that you mention it though, when the wheel is turned it does tend to flash faster.
Old Mar 7, 2006 | 08:12 PM
LittleDan911's Avatar
LittleDan911 is an unknown quantity at this point
YEah Chilton's Won't Tell Ya Much..... I Have Found This Out With Any Flasher Unit.... You Just Have Top Listen To Where The Noise Is Coming From... Whe You First Use Them... And That Will Direct You In The Right Direction....To Were Its Located
Old Mar 8, 2006 | 01:30 PM
blazingsadle's Avatar
blazingsadle is an unknown quantity at this point
Turn on ignition and flasher. Listen for clicking noise.
Replace with much more serious model intended for trailer use and do this even if you will never tow a trailer.
No matter what happens to increase resistance at one corner in the future; these modern heavy duty flashers will handle it and not break down.
Old Mar 12, 2006 | 06:16 PM
I'm going crazy here. I can't find the flasher. Sounds like it is coming from directly in the middle of the dash. Do I have to remove the stereo or take the whole dash off to get to it?
Aaarrrggghh
Old Mar 12, 2006 | 10:49 PM
4lowlife's Avatar
its behind theglove compartment door. Flip the door down. You'll see it.
Old Mar 13, 2006 | 03:13 PM
Finally got it. Evidently on the '97, some brilliant GM engineer decided it would be a good idea to put it behind the cigarette lighter. Not an easy thing to get to. Thanks for all the help though.
SubbinBlazer
May 24, 2013 12:56 PM
ta3ff
Oct 14, 2009 05:07 PM
shaka1111
Feb 13, 2006 02:23 PM
jf_stan
Aug 15, 2005 12:43 AM
blazin97
Jun 15, 2005 05:51 PM
