voltage low in reverse
Old Oct 25, 2018 | 06:17 AM
jimmy_for_ever's Avatar
jimmy_for_ever is on a distinguished road
Post voltage low in reverse
Hi everybody
I have a little problem with my 00 jimmy the voltage drop down when I shift to reverse its become 9 to 10 volt and become rough running but at D or N everything is OK.
Thank you
Old Oct 25, 2018 | 07:53 AM
Rusty Nuts's Avatar
Do both reverse lights work? The neutral safety and back up light switches are the same component in your auto trans.
Old Oct 25, 2018 | 09:50 AM
Arrow
yes both reverse lights work, I forget to inform that my car have dual electric fan for radiator and 2 more for ac condenser.
Old Oct 25, 2018 | 10:43 AM
Rusty Nuts's Avatar
There are 4 electric fans in your 2000 gmc jimmy? I'm sorry but if it's been altered that far from factory my long distance guessing may not be worth much.
Old Oct 25, 2018 | 11:42 AM
Rusty Nuts's Avatar
I still like the neutral safety/back up switch for causing the problem. It's possible that a broken one could kill your truck half to death when in reverse.
Old Oct 26, 2018 | 05:40 PM
Mike.308's Avatar
Originally Posted by jimmy_for_ever
Hi everybody
Thank you
Start with checking into Your underhood fuse box if none of the fuses has been altered.
It hardly makes sense You're having such a voltage drop and no fuse blowns or wires burned. That drop may be normal while cranking only. So either You have such a drop, because Your battery is dead (how is Your starter cranking btw? All good?) or You have some grounding connection problem. Check with a voltmeter connected directly to a battery if You have such a drop for real.
Old Oct 26, 2018 | 07:54 PM
odat's Avatar
c
Check the motor mounts too, in reverse the motor could be shifting and pinching a wire grounding it out - been there done that
Old Oct 27, 2018 | 07:45 AM
Originally Posted by odat
c
Thank you but motor mounts are new
Tomorrow I will check it thank you
Michaelm053
Oct 20, 2022 12:21 PM
Steve99
Nov 13, 2014 10:08 PM
rider22j
Apr 11, 2013 11:38 PM
JayDee240
Jun 17, 2012 11:52 AM
megaroos_00
Jul 31, 2009 10:26 PM
