voltage low in reverse
Hi everybody
I have a little problem with my 00 jimmy the voltage drop down when I shift to reverse its become 9 to 10 volt and become rough running but at D or N everything is OK.
Thank you
Thank you
yes both reverse lights work, I forget to inform that my car have dual electric fan for radiator and 2 more for ac condenser.
It hardly makes sense You're having such a voltage drop and no fuse blowns or wires burned. That drop may be normal while cranking only. So either You have such a drop, because Your battery is dead (how is Your starter cranking btw? All good?) or You have some grounding connection problem. Check with a voltmeter connected directly to a battery if You have such a drop for real.
Start with checking into Your underhood fuse box if none of the fuses has been altered.
JayDee240
Jun 17, 2012 11:52 AM
megaroos_00
Jul 31, 2009 10:26 PM
