wet floor
Old Apr 3, 2014 | 01:09 PM
yuri39's Avatar
yuri39 is on a distinguished road
Question wet floor
hi iam new here i have one problem i bought 97 blazer 4x4 runs great and all but when went to vacum it i noticed on the driver side floor under the mat was wet i clean it up with a wet/dry vac few days later was raining for two day it was wet again i went to check the windshield on top it sealed good but cant find where its coming from please need advise before the heat kicks in make it stink like wet dog . thank you for reading this
Old Apr 3, 2014 | 01:17 PM
You can check the door seal with a dollar bill. Close the dollar bill between the door and the body with the window open. Move it in and out while following the edge of the door. There should be a moderate amount of resistance. If it loosens up completely, the fit between the door and the body is not correct. Most of the time, this is caused by door hinge pin/bushing wear. If they are worn real bad, it can cause the gasket on the door to not seal properly. I have also seen bent window frames in the past.
Another thing to look at is the weather shield behind the interior panel on the door. There should be a plastic barrier that is glued to the door using butyl rubber. If that has peeled back along the front/back edges or at the bottom, it can allow rain to enter the vehicle. I had this problem on my old '01 Bonneville SSEi and I have seen others here have this issue with these trucks.
If you do end up pulling the door panels off to inspect the weather barrier, also check to make sure that the drain holes in the bottom of the door shell are open. If these get clogged up with debris over the years, it can cause the door to hold water which will then over flow at some point into the vehicle.
Old Apr 3, 2014 | 01:21 PM
jpimp's Avatar
jpimp is on a distinguished road
Is the coolant full?
Cracked heater core?
Old Apr 3, 2014 | 04:35 PM
Heater core is on the passenger side. Cooling system doesn't hold enough coolant to flood the driver side
Old Apr 3, 2014 | 05:22 PM
spittybays
Guest
Posts: n/a
OK, you got all the big brains on this one.
Open your hood, look for any leaf deposits, clean them out and get a can of air from Radio Shack and blow out every hole you can find.
You can also go to a saintly mechanic and for less then 50 bucks he will blow out every weep hole you have.
Old Apr 4, 2014 | 08:50 AM
jpimp's Avatar
Oooo, Drivers side. lol. sorry OP, I miss read your op.
Old Apr 4, 2014 | 09:10 AM
WalkGood's Avatar
WalkGood is on a distinguished road
You might need to remove the door threshold that holds down the carpet at door opening. Lift up under the carpet, I bet the padding is soaking wet and smells bad too.
Prop up the carpet enough to allow a fan to blow air under there. Spray with Lysol and Febreze. It's gonna take a while to get rid of that smell.
If you don't solve the water problem, it's gonna smell again and again.
Old Apr 4, 2014 | 01:42 PM
yuri39's Avatar
thank you guys going to do that now and thank you for advise. 97 blaze 4x4 mint condition it only haves 75k miles on it and been garage kept too since brand new ty again
ely0569
Apr 15, 2012 05:33 PM
littleblueblazer
Apr 25, 2010 02:43 PM
Flying3
Oct 23, 2009 01:36 AM
emf_1978
Aug 9, 2009 06:05 PM
bigbill23
May 29, 2007 01:25 AM
