Whacky fuel gauge
Old Dec 14, 2015 | 03:59 PM
JohnnyBlazer82's Avatar
JohnnyBlazer82 is on a distinguished road
Default Whacky fuel gauge
I have a 1997 blazer 4x4. The fuel gauge works and then tacks out to the right. Is that a ground problem and any suggestions on how to fix it?
Old Dec 14, 2015 | 04:02 PM
newguy's Avatar
Could be, could also be a bad sender on the pump. Removal required
Old Dec 14, 2015 | 07:10 PM
HardKnock's Avatar
HardKnock is on a distinguished road
Also check your connection under the driver side on the inside of the frame. The connecter there is your signal source for your fuel gauge.
Old Dec 15, 2015 | 12:44 PM
Do I have to drop the tank to access it?
Old Dec 15, 2015 | 12:45 PM
Tank and pump are new also
Old Dec 16, 2015 | 07:16 PM
burned's Avatar
burned is on a distinguished road
If the fuel pump was not replaced with a Delco or Delphi, then you can never be sure if the sending unit is working right. That particular year has a fuel level buffer module underneath the glove box. There is a rheostat on the pump that is connected to a float and that sends an ohm reading to the buffer.
I cant remember what the ohms full/empty should be for that year. Search the site.
Old Dec 26, 2015 | 07:53 PM
ACA1001's Avatar
ACA1001 is on a distinguished road
My fuel gauge works oddly too. Basically it goes down way too fast from full. It will go down to like a quarter of a tank but then if I refill it, I'll find that I had half a tank left. It will eventually go down to right above the red line, then stay there for awhile, then start going lower with the Low Fuel warning light eventually coming on. However, I am not sure if that is still an accurate reading or not, as when it gets that low, I do not usually drive it too far as I get nervous. So I haven't really been able to test the range I can go with it down that far.
One thing, but what is the range on the Jimmys/Blazers with an 18 gallon tank? My fuel gauge gives about 200 miles before getting right above the line, but that seems rather low...? I ask because if I know the proper range, I could probably calculate the amount of fuel left when it gets to that point. I suspect that with its mileage, that it is getting a lower amount of gas mileage though.
Old Dec 27, 2015 | 10:32 AM
ACA? Bag thrower? Lol I have a 97 and it has a 16 gallon tank. My gauge read 1/4 tank and when I went I fueled it up only took 8 gallons. Everybody telling me sending unit is worn out. Probably guna drop the tank (which is brand new) and replace fuel pump. And from the looks of the fuel lines I'd guess the pump is new also.
Old Dec 30, 2015 | 06:10 AM
ACA1001's Avatar
My fuel pump is new, however I'd have to check this thing called the sending unit.
JonZRDeuce
Feb 5, 2012 06:38 PM
hoppy26
Jan 26, 2012 02:08 PM
bdashwood87
Jan 3, 2011 10:20 PM
Mulisha
Mar 24, 2008 09:14 PM
